V8i SS3 - Cell Selector Will Not Load
Greetings-
I'm trying to use Cell Selector with MicroStation V8i SS3 (08.11.09.397).
I cannot get it to open; all it will ever do is open this dialog asking for a Cell selector file:
I do not have a CSF file but I would like to create one.  My understanding is if there is no CSF in the directory specified by MS_CELLSELECTORDIR, or if it is undefined, Cell Selector will load the library attached to the current DGN  (if in fact one is attached).  I do have a library attached to the DGN.
Other things I have tried:
  • I have attempted to use Cell selector in multiple files.
  • I have attempted to use Cell Selector with different clients (configurations/microstation environments).
  • I have attempted to load Cell Selector from the menu (utilities --> Cell selector), by mdl load cellsel keyin, and by mdl silentload cellsel keyin.
  • When using the keyns, I have tried it both without a filename following (I do not have a CSF to keyin), and also with a Cell Library in the keyin field.
All of these attempts merely gave the dialog above; Cell Selector did not open.
In the dialog asking for a CSF, I have tried both the "Open" and the "Cancel" buttons.  Clicking either does the same thing: nothing.
I have also tried setting the filter to files of types *.* (All Files) and then browsing to a cell library.  When I do that, nothing happens.
Every attempt to get Cell Selector Open does not work for me. Other users at this site have this same issue; we have a mix of SS2 and SS3 install and either version exhibits this behavior. I have got to be missing something... I'm open to any suggestions.
Thanks!
  • Works that way for me.
    You sure you don't have something set? Is it Just your PC? Could be something set/not set in your customized WorkSpace?
    Is this set to a location (MS_CELLSELECTORDIR)?
    Is this set to a location(MS_CELLOUT)? I'm thinking it may not be able to create that temporary "Untitled" csf
    Both of my variables are set to the same location.
    I Hope This Helps Someone Reading This!  (Intergraph>PseudoStation>MicroStation user since 1980's)
