Dear Friends,
How can I pick the coordinates of desire locations?
Thanks.
Use the mouse or any other input device ;-)
OK, Sarwar as you can see or read, IMHO you do not gave us enough information with your question what you really like to do.Please a picture would help all here!
What is your issue?
What Microstation command have you in mind?
Frank
Please finad attached a link describing in detail, how to assign a geocoordiante system:
communities.bentley.com/.../assigning-a-geographic-coordinate-system.aspx
Sarwar,
What is it that you are trying to accomplish. Do you want to find the coordinates of an existing point or place a new point at a specific coordinate? Your workflow would also be helpful and what end result you expect.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Frank, im sending on screen shot, like this i want to pick coordinates
Hi Sarwar,
Have a look at this thread:
communities.bentley.com/.../266980.aspx
...and the related thread to Civil toolscommunities.bentley.com/.../civil-tools.aspx
hth.
Henk
Answer Verified By: Sarwar Mukhtar Masih
