Changing running coordinates display
{Posted on behalf of Be Communities user}
In MicroStation V8i Select Series 3 you are able to display latitude and longitude coordinates by selecting my the active acs  in the "Auxiliary Coordinate" dialog and defining geographic coordinate system and using the keyin 'set tpmode acslocate.' However, is there a way to change the display to show northing and easting values with a labels denoting the northing and easting values respectively?
