I have a problem with invisible elements who can not be deleted.
Attached you can find the cleaned drawings with the 6 elements on level 401 I can not see, not select and so not delete.
In the level manager, the level 401 is marked as used with 6 elements.
On the drawing, I can not see any elements. Also a "select all" by the element selection tool does not select anything.
Also by selecting the level 401 in the "selection tool" nothing will be found.
But in the level manager, when i open the properties from this level, under usage elements are listed. And also a remapping from the elements to another level is possible.....
Does anyone know whats happened here....
Thanks a lot for any help
Raphael
This is a report from Axiom Filefixer v8
Original file format: DGN V7No seal-of-approval was found.Non-model Section16, ID=438035 -- Type 6 (shape) range misses its vertices by 50.0%. [305].22, ID=438037 -- Type 6 (shape) range misses its vertices by 50.0%. [305].25, ID=438038 -- Type 6 (shape) range misses its vertices by 50.0%. [305].Model (2D): Elevation 100.00MDescription: Elevation 100.00M4000000, ID=528010 -- Element type 14 (complex shape) is invisible. [240].4000001, ID=528011 -- Element type 16 (arc) is invisible. [240].4000002, ID=528012 -- Element type 3 (line) is invisible. [240].4000003, ID=528013 -- Element type 16 (arc) is invisible. [240].4000004, ID=528014 -- Element type 3 (line) is invisible. [240].4000005, ID=528015 -- Element type 3 (line) is invisible. [240].
Non-model Section
After fixing the file and making elements visible it seems they are part of a some complex shape.
