A co-worker of mine has on multiple occasions attached reference files to a drawing file and the references are not displayed. The 'display', 'snap' and 'locate' options are all checked in the reference window and all the levels for the references are 'turned on' or displayed. We aren't sure what the problem is. We are using V8i. Anyone have any thoughts?
Lori Beth Wilson
Hello Lori,
One suggestion (which you may have done) is to fit the view after attaching the reference, it could be located far away from the location currently being viewed in the master file at the time of attachment.
Another would be to check that the correct 'Model' is selected in the 'Reference Attachment Settings' dialog, if the wrong model is being attached, it could be an empty model and therefore nothing will display in the master file.
This thread is a duplicate of another thread, please see replies in this thread
