I have a strange problemI need help with.
When I save an image out using the screen display style Iseem to get some odd models floating in the background of the image, seeattached images.
Changing the output resolution changes the way they a laidout. You need to render with a high resolution to see this, around 3000 pixelsor above.
This does not happen when the display style is set to notshow shadows.
I created a new file and imported the saved view (andcreated a new view ) and it still happens. I’ve attached the file.
I does not seem to happen with every view.
The same happens on different machines under differentlogins.
V8i SS3_08.11.09.459
Please help!
Many thanks,
Richard
Attached is the dgn and some screen shots
Hmm
Tested up to 30000 pixels (attached the 10000 pixel .jpg output - to save some space) ...but everything appears OK
Maybe a driver/OS issue (NOTE: SWA was out of this world).
best, Peter
strange that it's happening to us. I did adjust the swa to bigger and smaller with no affect.
are you thinking a graphics card driver issue. Not sure where to start if it's an OS issue. running w7.
I'll try it on some other machines with different graphics cards.
thanks
Unknown said: are you thinking a graphics card driver issue.
These "artifacts" remind me some unfortunate Beta Rhino5 builds (bugs, bugs and then some).
My feeling is that your issue is a card related thing.
Case tested with various Quadros (I don't have/use game stuff) in XP/W7.
