My 3D model is made no where close to 0,0,0 coordinate, which creates a problem when change view rotation. So If have a top view and change to a front view (in the same window), then my model is way off in space, and it takes a bit to find my model again and zoom back in. The same problem happens if I use "RV=-90" keyin command. I know why this happens, but don't know if there is a solution, that does not require moving my model close to 0,0,0. I have a partial solution by using dynamic rotate, I first press tentative snap somewhere on my model and then rotate. This way I end up with my model still in my view window. thanks
Have you looked into setting an Auxillary ACS? This may help your situation. I don't work with this myself so I can't give any suggestion on how to set it up. You can search the help files for more info.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Yes, I know how to do that, but don't see how that would help me. It looks like the proximity of 0,0,0 is not a factor for my problem after all. It's more because I have temporary construction and other junk far away from my model that creates this problem. So my work around for now is putting all that stuff on a different level and turn it off, then when I change views the model is still in my view wiondow. For now it's my work around solution.
I wish I could snap tentative on my model and then switch from a top view to a front view and then my model would still be in my view window, this method works with dynamic view option.
Microstation select series 10 ver 08.11.09.919
also have
CONNECT Ed Update 17
Version 10.17.02.61
You can store views away (Utilities > Saved Views) to recall whenever you want it later. Then when you want the Front1, Top1, etc. just recall it. It will store Levels on/off Area of file you are looking at Active Z and Display Depth settings.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
you could try the ISOLATE tool and then save this as a saved view. This should only show the data that is within the isolate window
Ian
Bal
Good news: The "generic" way to control remote collections of objects is via clips. Exploit Model "things" and "more things" to see why (when in a "controlled volume" - clip thing, that is - use a local ACS to orient local "standard" views)..
Bad news: Unfortunately Clips in Microstation are not developed (at all) with contemporary 3d work in mind. A simple test to get the gist of my meaning : can you understand in a glance what's happening in Model "more tings" and why these 2 Refs are shown that way?
Ugly news: What if I had to manage a myriad of nested combos - as is the case in real-life complex AEC projects?.
best., Peter
