[V8i SSS3] MrSID files cannot be attached in the raster manager
These files come in correctley in ESRI ArcMap and in the correct coordinate system, but when I try and bring them into Microstation in the raster manager I recieve the following error.
"The file type is not supported - [13]"
Typically when I bring in a raster all that is required is a few supporting files which are there.  I initial thought that the data had been corrupted in the process of being transferred to me so I had it resent, but that is not the case either.  Does anyone have any idea how to remedy this?  I also tried using ArcGis to export the .sid files to many different file formats (.tiff, jpeg, etc.) all with the same error message.
