You can now register for our sixth MicroStation SIG event which will be a Point Clouds to 3D BIM! Learn how to create 3D BIM models from scans of existing facilities such as buildings, process plants and more!
Register for MicroStation SIG: Point Clouds to 3D BIM!
Online Event: MicroStation SIG: Point Clouds to 3D BIM
Live Q&A Webinar: Tuesday, January 14th at 8:00 AM PST or 3:00 PM PST
Cost: None! Must register for video links and connection info. Register here!
Description: Learn how to create 3D BIM models from scans of existing facilities such as buildings, process plants and more. The integration of Bentley Descartes and AECOsim Building Designer enables creating hybrid point-cloud/geometric models. It enables AECOsim Building Designer users to quickly generate intelligent BIM models from existing point-cloud data in a robust multi-discipline environment. Also, be introduced to Bentley Pointools V8i for pre-processing point clouds for distribution and re-use. Edit and manage point-cloud data from nearly any scanner. Create walkthroughs of point clouds.
To register for MicroStation SIG: Point Clouds to 3D BIM, please visit the BentleyLEARN site: http://learn.bentley.com/app/Public/GetLiveCourseOfferings?CourseId=107996&lpId=105422&FreeForAll=False
After registering you will receive links to videos to watch before the live webinar on January 14th.
Post questions for Live Q&A here!
I registered with the live webinar and would like to assist again cause know i want practice with different elements and generates files
