True Hidden Line presentation
I have noticed that cells or shapes that are filled do not show up filled in the "True Hidden Line" reference file presentation. Is there a setting I may have missed or is the as designed? Note: The filled cells shown on the graphic were put into Layout after the presentation was set for demonstration. [V8i SS308.11.09.459, BRCM, Promis-e, OpenPlant Modeler, OpenPlant PID, STAAD, RAM, ProSteel, InRoads, FlowMaster, Map, PondPack, StormCAD, Descartes] [V8i SS308.11.09.459, BRCM, Promis-e, OpenPlant Modeler, OpenPlant PID, STAAD, RAM, ProSteel, InRoads, FlowMaster, Map, PondPack, StormCAD, Descartes]
  • Mike,
    I think you are seeing a "Works as Designed"  Fills are treated as surfaces and rendered accordingly.
    Depending on where these fill elements exist you may be able work around this by setting your attachments to use different presentation settings.  i.e.  A 3D reference can be rendered as hidden line and a 2D will fills can be renders as wire frame.
    Answer Verified By: Mike Francisco
Reply
  • Mike,
