Despite having the elements set to not be visible in a dgn files, the clip boundaries from clip volumes appear in the Navisworks sessions. Has anyone found an easy way around this without having to set up vb to find and delete transient elements before you create the Navisworks files?
Hello Bear,
Can you upload a simple test case?
Or provide a basic description of what it takes to reproduce the issue?
Also, what version of MicroStation are you using?
Thank you,
Dan Koval
BSW Solutions Manager
