Draw Line between two lines at a specific distance
Good Day everyone,
I was asked if there was a way to draw a line that has a specific length (say 10ft) between two elements.
Any suggestions are welcome.
Parents Reply
  • You can also use Accudraw. If you start the Line or SmartLine command with Accudraw on, You can snap to point A then (make sure Accudraw has focus) type RE (Rotate to Element) Accudraw compass should rotate to selected element then use keyins for distance/angle (or distance XY depending on Accudraw setting) and second data point to place the line.
    Microstation CONNECT - 10.17.2.61
    ORD - 2021 R1 10.10.1.3
    ORD 2022 R1.1 - 10.11.3.2
    ORD 2022 R3 -  10.12.2.4
    ProjectWise - 10.0.3.453
  • how do you place any length line midway along an alignment between the elements in the featured example...
    I think I can do it in accudraw with O  on first point snap centre then o again send line centre snap then  mid point snap? on what what if I want my line 10units long .. too hard easier to draw line  centre to center draw circle 5r at center point on horizontal line and trim line to circle  then delete circle  yes its old school but one has total  confidence its perfectly correct..
    Lorys
    click link to PM me
