ex :
have a line with 100 vertexes ,
i want to place fence and just deleting the vertex inside that fence ?
Eburshaid,
as far as I know it is only possible using VBA or MDL programming.
But depending on our situation it may be possible to "drop" the line string delete the wrong parts and then "create a complex chan" again.
Regards, Stefan.
This question and others you have posted suggest that you are involved in GIS or mapping. There are GIS tools that might provide a better solution for your work.
i am in photogrametry field , using Microstation to Build 3d map
Unknown said:I am in photogrametry field , using Microstation to Build 3d map
Then take a look at some of the Bentley Systems products. They use MicroStation as the base platform, and provide GIS and raster functionality.
Cadastre and Land Development
GIS
What about DELETE VERTEX tool?
regards / Thomas Voghera
