I have a large number of .dwg files that I need to save as .dgn. Now the .dwg files will open in Microstation Powerdraft and I can export them individually but this will be time consuming. I am using XM version and there is no "batch" option under the utilities menu.
I am not sure if it is easier to do this through Microstation or AutoCAD.
Any help greatly appreciated.
I have found it but DGN is not an option in the output list.
Defualt Output fomat: V8 and V7 are DGN formats. You will want to use V8 as that is what the current version is that you are using. V7 is only for going to the older format before V8. an example is if you need the files in a DGN format for the MIcroStation J version.
Thanks. Got it working but some DWG files seem to fail while others convert ok. The files that are failing open in microstation fine.
Any clues?
Are you getting an error message ? If so can you provide the error message or a screen capture.?
No error. Just a "Failed" in the status column
