Still adjusting to V8i...
With V8 you could remove Enter Data Fields by editing text and removing the << >> surrounding the text. How do you manually convert an EDF to normal text in V8i? Can it be done?
I've searched and searched and can't find a way to do this.
Unknown said: Still adjusting to V8i... With V8 you could remove Enter Data Fields by editing text and removing the << >> surrounding the text. How do you manually convert an EDF to normal text in V8i? Can it be done? I've searched and searched and can't find a way to do this.
there is / was a vba macro that bentley select support built for someone... that just drops all of them in a selection set / fence to plain text...
if Bentley Select Support cant find it for you or no-one posts one email me offline and I see if I can find a copy in the archives........
alternatively post your request in the programming vba section and ask if anyone could make a macro that turns enter data fields to plain text... or give you advice on how to do it yourself...
Lorys
Lorys, did you ever find the VBA in the archive?
I've come across this issue myself in v8i and was wondering if there was a way to drop the data field to standard text.
Thanks.
Peter
your offline email address is not registered in your bio so if I find the said macro in my archives I can't send it...
