I'm trying to better understand Line Style Parameters' "Width Mode", "Constant Width", and "True Width" settings. I would like to add a specific width to custom linestyles. It doesn't seem to matter what settings I use the custom linestyle's width doesn't change.
I've tried changing the settings using the Custom Line Style dialog box before placing custom linestyles and using Element Information dialog after they are placed and neither seem to have an effect. I've looked at the custom linestyle settings with the Line Style Editor and am not sure if I have to change something there.
Attached is a sample file and the linestyle resource file. It's probably something I'm overlooking but can't seem to put my finger on it.
Any help is appreciated, thanks.
The LineStyle has that (ability to set width) setting turned off (Width=None) If you set it to Full it will allow you to adjust width. Actually all the LineStyles have that set to None.
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
Answer Verified By: jwingfield11
That was it. I thought I had changed that but I must have not re-loaded the resource file properly.
Thanks for setting me straight, I knew it was something simple I was overlooking.
