Thank you for the screen capture, can you provide exact steps to get to the functionality you are attempting to use?
Thank you,
Dan Koval
BSW Solutions Manager
Vladimir Manichev
BMSTU, Moscow
Just to clarify, you mean the amount of space between characters when placing the equation?
yes, there are a lot of amount of space between characters when placing the equation
Defect #85259 has been filed
But as a work around you can:
1. Select the OLE Object so the Edit Handles are visible
2. Select one of the edit handles to see how it is expanding, if it expands in both directions at the same time, press the ALT key to prevent the expansion from scaling.
3. This will allow the formula/ object to be able to be condensed
Answer Verified By: Dan Koval
ok., many thanks for help
Answer Verified By: Vladimir Manichev
