Installation error 1602
We use Microstation/Powerdraft on Windows XP running on Parallels. After one workstation had issues I deinstalled and tried to reinstall Microstation but each time the installer fails with error 1602, the message says that 'user cancelled installation' but it is just cancelling all by itself without me doing a thing. Any ideas...! would be very grateful.
  • Hi, I have tried a completely clean install on a completely clean install of a new virtual machine and still get the same error. It is running Direct X9 as it is XP and Parallels 3 (I know, a bit old but it is an old-ish machine)
    I have found the log files, the last bit in the log reads
              ******* CommandLine: **********
    MSI (c) (E0:84) [00:17:31:670]: Client-side and UI is none or basic: Running entire install on the server.
    MSI (c) (E0:84) [00:17:31:670]: Grabbed execution mutex.
    MSI (c) (E0:84) [00:17:31:690]: Cloaking enabled.
    MSI (c) (E0:84) [00:17:31:690]: Attempting to enable all disabled priveleges before calling Install on Server
    MSI (c) (E0:84) [00:17:31:690]: Incrementing counter to disable shutdown. Counter after increment: 0
    MSI (s) (E8:30) [00:17:31:690]: Grabbed execution mutex.
    MSI (s) (E8:BC) [00:17:31:690]: Resetting cached policy values
    MSI (s) (E8:BC) [00:17:31:690]: Machine policy value 'Debug' is 0
    MSI (s) (E8:BC) [00:17:31:690]: ******* RunEngine:
              ******* Product: C:\BentleyDownloads\PowerDraft_08.11.09.459\PowerDraft.msi
              ******* Action:
    MSI (s) (E8:BC) [00:17:31:710]: Machine policy value 'DisableUserInstalls' is 0
    MSI (s) (E8:BC) [00:17:31:710]: Setting cached product context: machine assigned for product: 04C33FF153AEFBC4B9652BC0CBFD1CCD
    MSI (s) (E8:BC) [00:17:31:710]: Using cached product context: machine assigned for product: 04C33FF153AEFBC4B9652BC0CBFD1CCD
    MSI (s) (E8:BC) [00:17:31:710]: MainEngineThread is returning 1602
    MSI (c) (E0:84) [00:17:31:710]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied.  Counter after decrement: -1
    MSI (c) (E0:84) [00:17:31:710]: MainEngineThread is returning 1602
    === Verbose logging stopped: 26/03/2014  00:17:31 ===
    You can see the 1602 error at the end. Thanks for any help!!
  • Please either include the log files or should you not wish to expose that type of information on the forum, start a service ticket with technical support.  Again, this environment isn't supported but from information in the log files we can tell you the exact source of the error.  All we have from this is that the installation was cancelled, purportedly by you (but I'm certain you're not cancelling the installation and then asking us why the installation was cancelled).
    ERROR_INSTALL_USEREXIT 1602 The user cancels installation.
  • Hi, the whole log is posted below - I didn't post it all last time as it is so long!
    [admin edit: The log file text was extracted and put in an ASCII text file that is attached.]
  • Unknown said:
    The whole log is posted below - I didn't post it all last time as it is so long
    You can attach a file to your post.  It's more convenient, for everybody, than cut-and-paste.  Use the Advanced Reply Editor , which provide a way to attach a file in the Attachments/Options tab.
    Regards, Jon Summers
    LA Solutions
  • Hi HanaL,
    Please attach the log located at %temp%BentleyInstallationlLog.log. That will help in analyzing all activities done by installer while chaining MicroStation installation with pre-requisite.
    ~Vishal
