Convert Surface to Shape Element
Dear All,
I want to convert a surface into shapes. Is there any options available in Microstation-V8?
Parents Reply
  • Unknown said:
    but will that work with 3d ... not all strings are planar ....??????
    It will work with 3d, but the result will be a planar shape. It will only create planar shapes.
    Shapes are inherently planar, so if the input surface is non-planar and the desired results are non-planar, the result would be multiple shapes, or facets, approximating the surface. Since Dharmarajan's sample shows a non-faceted shape as the desired result, I chose the Create Region Flood method.
