Is possible to add "References" in View Attributes ? ( i talk about this few years ago :)
I know that it's look good that is 12 options on the left and 12 on the right panel :) but please add References for quick turn off all
What exactly is being requested here? Are you asking for a option in the View Attributes dialog to turn on/off all references?
You mentioned that you have talked about this a few years ago. Had this been officially requested to our software developers via a Change Request? Would you happen to have a number of a Service Request or Change Request that we can locate for you?
I cannot locate a Change Request that may have been raised for this so maybe you could raise this again with SELECT support.
appsnet.bentley.com/.../addcall.aspx
there is a short cut extension to not load refs when loading a dgn ....ustation.exe/ W ???? something something...
been posted here before look at askinga...
But you want to toggle see refs no see refs ... I'm sure there must be a keyin or some vba you could add to an F key to facilitate this.... it would need to be done in the display manger not the ref manager as you dont want it permanent to be change ... hmmmm I'll have to investigate further....
Lorys
What is the diference between opening the view attributes dialog and opening the reference file dialog ? you are still opening a dialog, it doesn't take any longer nor is it more convenient,,,,,Just open the reference file dialog, and turn off the reference display there.
Timothy Hickman
Main: 877 627 3772|
Do you mean saved view instead of view attributes?
http://communities.bentley.com/communities/other_communities/askinga/w/askinga/attach-references-on-a-level-and-add-value-to-saved-views.aspx
Maria
Answer Verified By: martinezx
You can use this keyin to turn off/on all reference files "reference display off all", "reference display on all" or "reference display toggle all". You can also use the same keyin and specify the name of single reference file.
I created a custom tool button for "reference display off all" or you could add it to a F key.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
