hi all
with accudraw active, I'm not able to switch from rectangular to polar mode with the space bar. All other shortcut keys works.
Do you think is a installation problem?
Thanks Dario
Could you state what version of Microstation you are using? 08.XX.XXX.XXX?
Have you recently updated your version of Microstation to a newer version?
The shortcuts are stored in a file shortcut.txt.
Within Microstation you can find the location in the menu:
> Workspace > Configuration > Operation > AccuDraw Shortcuts
Can you ensure that it is pointing to the location of the Shortcut.txt file?
Answer Verified By: ampe64
Hi Dervalcanny
I'm coming from SE, then V8 XM, now I've got AECOsim V8i (italian version) version 08.11.09.599
Just now, I resolved the problem: Looking at the previous versions of "shortcut.txt" files (in SE and XM) I noticed that change mode shortcut had "Spaz" (that is for barra spazio) and not "Space". Editing the shortcut.txt file this way, made the command work.
Dario
Hi Dario,
glad to see the issue is now resolved for you!
Derval.
The following link could be useful if you encounter issues similar to this one again in the future:
communities.bentley.com/.../10590.accudraw-keyboard-shortcuts-such-as-enter-and-space-do-not-work.aspx
Thanks and Regards,
Alessandra
Thank you so much Alessandra :-)
