I'm making some plans for supports on piping instalattion, so this pieces are the same and are too many, by end, i would get a file around 168 MB (just the supports). Is there any way to convert/change regular normal cells into shared cells? I follow a procedure thru exporting to DWG and the importing again, unfortunaly i get a bad result like the one in the attachment.
I have several files like this one that I have to merge together with the pipes and some other information plus the paper spaces, in one test, I get a DGN file of about 768 MB, and that will be for one instalattion (building), that it is why I need to be shared cells. Plus, when using the precedure of DWG Export, change the scale of the shared cells to 10 times (Original DGN: Main Units=Meters, auxiliary units=mm)
There is a change request to have this ability CR # 321573
Any workaraound?, plus, how can I rename a shared cell?
You can rename a shared cell and all it's instances with the REPLACE CELL tool from mstn
Frank
Please find further information on shared cells here:
docs.bentley.com/.../ustnhelp1373.html
cant one just open the place cell dialog tool and turn on use shared cells then use cell replace command which would replace all the cells in the active file with shared cells...????
I dont think you have to create a shared cell first its just a setting option on how the cell is used when placed...
Lorys
