I am using Microstation V8i SS2.
I have created a chain using the smart line tool. Then have tried adding fillets to each pi location. I used the key-in to type DWG Fillet and Construct Circular Fillet Dialog opens. Once specify radius, I have added a few radii but I am not able to place all the radii. Instead of getting a fillet, I get an "Illegal Definition" warning. I changed the radius value to ensure I have enough line length to accommodate the radius and still no improvement. What is the likely reason I can not add all the fillets to the line chain?
Make sure your linestring is all the same elevation if you are in a 3d file. The line segments must be planar or the fillet will not work.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
If you placed the line string with the smartline tool, then you should be able to modify the vertex point. Select the modify tool, and then select one of the vertex points. The tool should allow you to change the vertex type from sharp to rounded, and allow to to assign a radius.
Timothy Hickman
Main: 877 627 3772|
The element information of the lines composing the linestring do not appear to have "Z" components, only x and y. But to be sure, is there a "Flatten" command in Microstation?
Are you in a 3d file? if you are in a 2d file then this should not be a problem.
You can search for Civtool.ma and load that set of tools which will allow you to change element elevation or use the modz.ma tool.
From MicroStation help:
Flatten CurveUsed to flatten or project a curve-type element, such as a line string, complex chain, complex shape, or B-spline curve, into a specified plane.
Key-in: FLATTEN CURVE
Answer Verified By: CADTech1
