Construct Bisector Angle tool bisects the (smaller) angle between two lines. Is there a tool that bisects the external (larger) angle between those lines?
With accudraw, you can bisect an external angle using only the Construct Angle Bisector command.
Try this:
Pick Construct Angle Bisector command
Snap to the angle point and type "O" to set accudraw origin.
Snap to other end of first line and then type "RQ" and "Enter" to rotate accudraw compass and smart lock to this axis
Move cursor back past the origin point and enter 1st data point
Snap to angle point and enter 2nd data point
Snap to end other end of second line and then type "RQ" and "Enter" to rotate accudraw compass and smart lock to this axis
Move cursor back past the origin point and enter 3rd data point
(See example video below)
HTH,
Ron
Unknown said:I am sure there is a way to do this by writing a macro, can anyone point me in the right direction?
Your are right, a reason why MicroStation offers different programming API is exactly this - to allow adding extensions when a particular feature / tool is needed but missing. To create such tool can be done in every API MicroStation has: C/C++, NET and VBA, where VBA is the most simple way. A question is what development experiences you have? If none or basic, it's usually faster (and cheaper at the end) to hire a developer. To create such tool is not complex task.
Quite often it's better to create own placement tool (which requires to implement IPrimitiveCommandEvents interface in VBA) from scratch than to use the original MicroStation tool and try to automate what you do manually.
Unknown said:Also, it seems like it would be possible for Bentley to add that option to the existing tool.
The best way is to create Service Ticket as Change Request and to explain why such enhancement should be implemented. I agree it looks like small change with a good benefit. But to create own tool is faster way, especially if to place a line in a different direction is the only requirement for this tool.
With regards,
Jan
Ron very good but Jans demo with just accudraw with smartline is easier , fewer steps.
Lorys
Unknown said:
Demo brilliant ! OMG Accudraw I love it!
thanks!
This tips going in the magazine for sure and I'll acknowledge it came from you here Jan
Great!
Thank you all for your suggestions.
