Is there a way to print a list of the references that I have in my dgn?
Open the References dialog and select all of the references.
Press Ctrl-C to copy the list to the clipboard.
Now paste it into a text editor or spreadsheet and format it for printing.
HTH,
Ron
Answer Verified By: J-Worker
You should be able to generate txt file of your references. Run Key-in: macro refinfo Refs.txt
It will generate txt file in same dir as your opened file.
Check other post: http://communities.bentley.com/products/microstation/f/140/p/45008/114713.aspx
The macro solution only works if you have the macro.
The copy and paste solution worked perfectly. Thanks for that!
The "refinfo.bas/ba is delivered with the software and generally located under Bentley/Workspace/System/Macros
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
