I used to be able to change element properties from the Element Information Window. Specifically, the Level and if it was a dimension, the DimStyle and Text Style. Now, those are greyed out. Is there a toggle to enable/disable this?
is the file read only ? or is it possible you did element information on an element that is in a referenced file ?
Timothy Hickman
Main: 877 627 3772|
File is Writeable and it happens on active elements, even if I just draw them and then immediately click into the Information Window for that element.
Foster,
What version are you using? That button doesn't exist anymore in Element Information window.
José
SS4 593 - it sure is there and has to be used otherwise nothing happens.
I'm sure were talking something different. Do you use other software on top of Ms? See my example:
I select my text and in Element Information I just click on the Text Style of my desired and automatically the text changes... Any change that I make in Element Information I don't have any button to apply that change.
Maria,
That link is dead for me.
Which UPF or cgf should I delete?
I attach the PDF. Let me know if that works for you
Maria
