Is there some way I can control the width of the project configuration drop-down menu in the MicroStation manager dialog box? Is there some way to have it dynamically fit to the width of my project configuration names, or at least widen it show more characters? In the case of some projects you can't tell what the project is cause the characters unique to the project name come at the end of the project config name. (see image).
Kind Regards,
Scott H.
CADad
There has been a change request to add this enhancement. CR# 289750
Answer Verified By: Scott Harmon
Another suggestion for that CR is to change the tool tip to one that dynamically lists the fully expanded project name when you hover over a project in the list. A lot of the InRoads dialog boxes have kind of narrow menus and hovering over them will show you the full width item. It is very helpful.
Currently it just says "choose a project". I'd suggest moving that tip to the Project: label, if that's possible.
Thanks Melissa,
Caddcop's suggestion would be totally acceptable too. Keep the width alone but show the expansion in the tool tip. Nice!
Scott
