White lines all through DGN file
Quite suddenly my co-workers dgn files open with all these lines in them.  I'm not very familiar with Microstation as I'm just the IT person but I don't think the lines that are showing up in this dgn as well as others are from video card issues.  I've already changed out the video and her computer is fairly new.  Other people in the same department are able to open the same file without any of these lines.  Only her.
Please help!
pLD-D002_Marburyedit.dgn
  • Thank you for everyone's suggestions!!  Apparently, Nvidia just released a driver that corrupts Microstation files.  It is GeForce driver version 337.88 and I believe it was released this past Monday.  Try not to update your display drivers with this if you can.  And if you've already done it, I would revert back to an old driver if you can such as 335.23.
    Answer Verified By: Tim Hickman
  • I have a similar problem viewing AutoCad files in Bentley View V8i (select Series 3) 08.11.09.459 and Power Draft V8i (Select Series 3) 08.11.09.459, with blue lines connecting just about all vertices. The preview file prior to loading does not have the problem, nor does the printout. I am running Windows 7 Enterprise 64 bit with an nVidia Quadro FX580 video card and driver 341.05. It doesn't seem to matter whether I save the AutoCad files to earlier versions, but I have not tested this exhaustively.
    Any suggestions would be appreciated.
  • I answered how to do this also below for those who dont know how to make windows variables...
    http://communities.bentley.com/products/microstation/f/273/p/108196/328432#328432
    Lorys
    click link to PM me
Reply Children
