New to microstation *
I'm trying to create a linetype that looks like this:
I'm not having any luck by going to element -> linestyles , and trying to create in there. Any advice on this situation?
Create a file in notepad with a .lin extension. Then import via Line Style Edit> file import
Should be something like this.
*MyLine, MyLine .... .... ....
A,0.01,-0.01,0.01,-0.01,0.01,-0.01,0.01,-0.08
Search Autocads online help for more details on line types.
If you are referring to creating a custom linestyle in a MicroStation ilnestyle resource file please refer to the two following links:
communities.bentley.com/.../10407.creating-a-custom-linestyle.aspx
and
communities.bentley.com/.../4188.aspx
Regie,
I tried those, I don't want text in my linetype. I just need a dashed linetype with the dotted style.
I created a new resource fileCreated a Stroke in it and called it "4Dash-Gap8"After adding the Dashes and Gap for the Stroke (Below)I created a name called "4Dash-8Gap"Then I "Saved" the resource file.
I guessed at spacing!
I added 4 Dashes at 1 with 3 Gaps of 1, Plus a spacing Gap of 8Made them all "Variable" andMade the Dashes Width "Full" (for flexibility)
Next Post has image of dialog
I Hope This Helps Someone Reading This! (Intergraph>PseudoStation>MicroStation user since 1980's)
Image of Dialog I created the Custom Line Style in
