I am new to Microstation V8i SS2.
I am trying to move a line so the beginning point of the line is set at 0,0,0 point in my model. I have selected the line, selected move, selected the endpoint of line as base point, then typed 0,0,0 into accudraw at bottom of screen. But the line does not move to that location. How do I move this line, and is there a key-in to accomplish this?
press F11-> press"m"
at Data Point Keyin type whatever co-ordinate you want.
Is there a way to "ID" a point on the screen to know its location?
An easy method of moving an element to a specific location would be to use the keyin XY= or POINT ABSOLUTE
In this case you would snap to the point on the line you wanted to move to 0,0,0.
Then keyin XY=0,0,0, and accept the move.
Further information regarding this and other keyins can be found in the Help Documentation.
docs.bentley.com/.../ustnhelp655.html
Answer Verified By: CADTech1
Unknown said:e a way to "ID" a point on
"Identify" the coordinate of that points? press you mouse left and right button together.
Unknown said: Is there a way to "ID" a point on the screen to know its location?
Turning on Running Coordinates from the Status bar may also be useful. For more information, see the Help Contents for the Status Bar
