How can I place a rotated cell that always keep the horizontal text?
In any rotation always I want to see the result 6.
See image
Joaquín
Oh, right, my mistake. Thanks for setting me straight.
Sorry Joaquin.
Hello jwingfield,
did anyone get a solution on this? I am running MS V8i SS10 and I'm having the same problem.
Thank you,
Armando
the only way I have been able to over come this is to make the original cell without text , put an active point Non print level where the insertion point for text would be and either have another cell with the text ( ie a number with and active point and text placed at the active point ie the number 9 or 6 in your example at the right size then place the first cell rotated then place the second cell ( or plain text is easier) at the active point then group the two in case you need to move them..
We then could make a script to place the first cell by name and by rotated then just add place text with level, weight color font and size.. but I think manual add text easier.. yes too bad the text independent view rotation is not an attribute for text in cells
Lorys
I have created an IDEA this this as it isn't going anywhere......... 2014 this was posted . 9 years later.........
Place Cell with horizontal text | MicroStation Ideas Portal (aha.io)
I came up with a method that you may find useful.
To use this new Graphic Cell:
This video shows how it works:
Here the example cell I used in the video:VI_tag_example.cel
Regards,Ron
