Is there a way to set pattern angle by selecting an element or by 2 points.
I'm not sure whether this is going to help but keyin to define the pattern angle is PA= or ACTIVE PATTERN ANGLE. This can be used outside of the Pattern Area tool but I cannot see any need to do this outside of the tool as it only allows a value to be entered. A quick search did not seem to locate any Enhancement Requests for this capability. You might like to request this via a new Service Request.
appsnet.bentley.com/.../addcall.aspx
The following thread also has some additional suggestions on retrieving and setting the active angle ( Not pattern angle ), which may be of help in at least obtaining the angle for pasting into the patterning tool settings or using the PA=<angle> keyin.
communities.bentley.com/.../288269.aspx
Carl Myhill
Technical Support Engineer
Bentley Systems
You can use the match pattern to match the pattern angle.
I know about (Pa=) and I tried the match pattern angle to a element and that does not work in ss2. That only works with existing patterns. I want to set my pattern angle by an element that is not a pattern
Kirk
I Wish Cadland was Reality
Can you use the new Element Information dialog to find the angle reported within for the element and then copy and paste that into the pattern tool settings?
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
