Is there a way you can rotation a text to be exactly parallel to a given line? I was thinking maybe there might be a command where you could click on a text then click on a line and it would rotate the text automatic parallel to the line or something to that effect. thanks
tried it and it worked great (with a couple less clicks yes), thank you!
