is there a way to digitally do a "redline" mark-up in microstation
is there a way to digitally  do a "redline" mark-up in microstation? with like a freehand electronic pen (wacom bamboo) or something to that effect.
  • Bentley Navigator allows reviewers to create "overlay" files with "markups" for each issue that needs to be redlined. There are specially designed tools available for freehand remarks. Markups will maintain its history, they can be commented, assigned. A designer that receives the overlay or holds it in the same project folder as the original file will see "markers" at the position of the "markups". The designer can correct the issue and reply directly within the MicroStation Markup dialog.
    Answer Verified By: geewizz
