Have the TAB Schemes been removed from MicroStation SS3 even though it is still in the Help file?
Do we have to set the TABS each time we place text.
I found a tabschemes.csv file in the prefs folder but it has nothing in it. Let me guess, it's not compatible with Excel 2013?
Not Sure why the menu item is no longer present but you can still use the keyin "wordprocessor tabschemes" to access the dialog.
No that does not work I get "Unable to load dialog whose id is 41510004" error with that key-in.
[V8i SS4 08.11.09.829, BRCM, Promis-e, OpenPlant Modeler, OpenPlant PID, STAAD, RAM, ProSteel, InRoads, FlowMaster, Map, PondPack, StormCAD, Descartes]
I managed to reproduce your error, with the Text Editor open and using the keyin the dialog will appear.
I have also subsequently spoken with development and this functionality had been removed, and unfortunately the keyin / help was left behind. It is removed completely in the next release.
Should you require the functionality this provided or have other suggestions for improvement please file a Service Request with Support requesting the enhancement.
Answer Verified By: Mike Francisco
Carl
The question you should ask the Bentley developers, "Why did you remove this functionality?" I've wasted a whole morning now trying to create a columized table in Microstation and I'm about to give up.
Neville du Plessis
Rail Design
