Running Microstation v8i, version 08.11.07.508 on 32-bit Windows 7
We recently switched from XP to Windows 7. Since the switch, text comes in view-independent by default.
I want to it come in view-dependent by default. It used to do this. I've searched these forums and Google, but can't find the answer. I'm sure there's a setting somewhere, but where?
Three questions...
1.) Is existing text in these files view-independent as well?
2.) What happens if you open your file in a new workspace?
3.) This is generally not a design file setting so next question is are you running in custom applications in your environment?
Thanks, those questions were helpful. There's no existing text and I'm not sure how to open a file in a new workspace, but it occurred to me that all the files I've been working in lately were created by copying the same existing file.
So I went back an opened an old file that I never had problems with, and created a new one from a different seed file. Those were fine.
So how do I change the setting in a design file so text comes in view dependent by default?
Could you attach a file that you created by copying from one of these existing files? Just place one string of text in file.
File attached.
This file contains view-depedent text and when I placed new text it is view-dependent. How are you verifying that the text is view-independent and not view-dependent?
