Hi
Can anybody help me to resolve the error. I unistalled microstation and re installed it, but the same error appears.
Thank you
Hi Hennie,
you have not provided enough information to help you (I recommend to read Forum best practices at first).
Display problems are often caused by old video drivers or by corrupted design files.
With regards,
Jan
Answer Verified By: Hennie Britz
Hi Guys
Thanks for your reply, it was my graphics card. It works fine now
Thank you for your time
so what did you do exactly to resolve the graphics card problem,,, someone else may have same problem... so just replying "........yes it was my graphics card "
That doesn't help anyone else.. right?
Lorys
That looks like the same situation we've run into with NVidia graphics cards and the latest driver release. There is a problem with the most up-to-date driver (don't know which cards are effected) so you need to revert back to the previous.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
Nvidia have released a driver that affects Microstation files.
It is GeForce driver version 337.88 . It is recommended to revert back to an old driver if you can such as 335.23.
Derval.
Hello
It is the nvidia driver, I used the nvidia control panel to make bentley use may onboard graphics card and not my nvidia card. You can also revert back to a previous driver as suggested by the other postes
Unknown said: Nvidia have released a driver that affects Microstation files.
To avoid misunderstandings... I don't think that the driver really 'affects' the files. It's rather a display issue for direct X graphics. We encounter the same thing here, but open GL based CAD seems to work fine.
Also this seems to depend on the hardware running the bad 340.52 driver. I could verify that this one does NOT work for Quadro FX 3700, Quadro FX 3800 (although listed as supported). On the other hand a machine running a quadro K2000 340.52 seemd to be OK.
Can somebody confirm other graphic boards that seem to be OK. Perhaps we can summarize this as 'older boards are not recommende with 340.52'?
