import saved view
when i import a saved view some things are not working as i expect
1. there are no names visible in the list of saved views only an icon but if import the view (as indicated by the existance of the icon) the correct name appears in the saved view dialog of the file i'm in.
2. when i restore the view the levels remain unchanged the only change is the correct camra view is displayed
i'm using microstation version 08.11.07.443
  • Sorry for the delay in responding to your issue. It seems like this post had been overlooked.
    Is this issue still a problem for you? Maybe you could provide some screen captures or example design files to show exactly how this looks on your system. Have you tried upgrading to the latest release of MicroStation V8i (SELECTseries 3) 08.11.09.459? Maybe a newer version has fixed this problem.
    Andrew Bell
    Technical Support
    Bentley Systems
