I am using Microstation Version 08.05.01.25 Windows x86 and Operating system is WindowXP. When I attach a TIF Image (of about 1GB file Size), it displays a bounding box only and not the content of raster. How to fix this?
please be aware that the version of Microstation you are using is not certified to run with Windows x86.
This may be the reason you are encountering issues with attaching your raster file.
The first MicroStation certified for Windows 7 (both 32 and 64 bit) is MicroStation V8i SELECTseries 1.
A discussion on this issue can be found here:
communities.bentley.com/.../46151.aspx
Unknown said: The version of Microstation you are using is not certified to run with Windows x86
I think you misunderstood the x86. That means a Windows operating system intended for Intel x86 32-bit architecture (e.g. a Pentium or iCore). It does not mean a 64-bit OS, which seems to be your interpretation 8-)
Thanks Jason. It works fine.
