Level color overrides not saving on exit
No matter what I do, my level overrides will not save after I exit.  I:
  • Have Save Settings on Exit toggled on.
  • Have tried manually saving settings
  • Have level overrides on in view attributes
  • Have toggled DWG Visretain between 0 and 1
  • Have toggled SET REFLEVELOVERRIDES on and off
Does it in the main file and references.
Matt
  • Hi Matt,
    Does this happen on all files you open?
    Does this happen on other workstations?
    Is this behaviour new?
    One thing I can think of is to check if "MS_LEVEL_AUTO_SYNC_ATTRIBUTE_LIST" or "MS_LEVEL_SYNC_ATTRIBUTE_LIST" have been defined.
    Go to pull down menu: Workspace > Configuration > Levels > Level Attribute Auto Sync.
    This autosyncs levelattribute on file open.
    Go to pull down menu: Workspace > Configuration > Levels > Control Level Attribute Sync.
    This controles wich levelattribute will sync when you sync manually.
    If Auto Sync is defined try to undefine it. If defined, there probably was a reason to. If undefining is impossible, ask the CAD guru in charge how to proseed.
    I've never bothered to see how this responds though, so I could be wrong.
    Good luck.
    Ivo Blaauw
    Look what the CAD dragged in...
    Answer Verified By: Matthew Kuehl
  • look at the ref manager and check if overrides set to never by mistake...
    Lorys
    click link to PM me
  • Control Level Attribute Sync worked.  Thank you very much.
