How to show more files on the file pull down menu?
The version of MicroStation is V7 as show in the below only four files show up, are there any ways to show more then 4.
  • The MDL file open dialog in MicroStation/J only displays the last 4 files opened (if MS_FILEHISTORY is not set to 0). In V8 generation products (including MicroStation V8i), this "limit" is similar to that of other Windows applications. Note that there was a customization floating around that provided a separate ability to recall previous files, but that was a long time ago :)
