XYZ TEXT Export
I have read several posts regarding the XYZ text export command but none with the same problem i am having.  I am using Power Civil and Power Survey on a 64b machine with windows 7OS.  the results of the export are all zeros (0,0,0)? I have tried all the ASC comments with no success.  This routine worked fine as an MDL command using V7.  Since we use this feature on a routine basis I would appreciate any suggestions.  Please let me knwo if you need additional information about version or PC?
