Delete raster functionality
I picked on the delete icon and deleted an element from a file. I then went to the raster manager window to move a raster. I picked the graphic file name in the raster manager and it deleted it. Is there a way to get it so the delete element command doesn't delete raster files that way?
  • To disable the "Delete Element" tool on raster elements, use the following key-in: RASTER DISABLEDELSELECTION SETON.
     As for the "Element Info" dialog, it is not possible to disable it on raster elements. This dialog is used to show and edit the attributes of the raster attachment.  But, if you have a mixed selection of vector elements and raster elements, notice that you can select - in the "Element Info's upper pane - which elements information are displayed in the dialog.
     This is a test
Reply
     This is a test
