Need help working from home with your Bentley software? We're here to help - click here
Saved views not working in Google Earth
Hi All
I am trying to save some backgounds from Google Earth to use as an environment when I render images of my model.  I have exported the model file to Google (KML) and it comes through in the correct location with the saved views. I would like to use the saved views in Google to save an image as a backdrop that matches my model saved views. When I click on the saved views in Google, I should get the same saved views from the dgn model, but Google navigates to a different location each time.  It is almost as if the view it goes to is in the same orientation as the saved view, just a little too far away (couple of km).  Does anyone have a solution, or an idea?  I though perhaps the geographic coordinates, but the model is in the correct place in Google, just the views are not.  Help!
-W
