Need help working from home with your Bentley software? We're here to help - click here
Change Case - why isn't it part of the default Task menu?
There's a task menu for text and there is a toolbox for text. The toolbox has 4 additional items. Can the Change Case command be added to the task menu? How can I add or replace it? Also in the WP text editor you can do a change case for Upper an lower only. Can that be upgraded to include Title and First Capital? And also have it remember the previous setting so you don't always have to reselect. I think the previous change case mdl from pre XM had that capabilty. Thanks!
