Function key and button assignment, *.mnu file loading
When upgrading to V8i, my mnu-files don't load automaticly anymore. The files are located and defined at $(HOMEDRIVE), and this is also where I'm directed from the dialog box for manual loading. So everything seem ok, the congiuration variables are set correctly, the "homedrive" and the mnu files exists, but the files are not loaded at startup. I hope someone might give me a clue on this one.
 Mvh
Morten G
