What is cfg file syntax for v8i VERSION number?
This should be an easy one, but I can't find the answer anywhere.
What is the correct syntax for specifying the V8i version in a config file?
For example, for version XM in the config I say: %elif defined  (_VERSION89)
What is the number for version 8.11? I tried _VERSION811, but that doesn't work.
Thanks,  Karen
