Project configuration
for one project I don't need some dgnlib's (located in the upf file). I redefine the MS_DGNLIBLIST = ... in the pcf file, but still the whole list of dgnlibs for my standard workspace is loaded true the upf file.
Is the pcf file not the last list that loads?
Haw can I define this overwrite in the pcf file, without changing the upf file.
* all my users have a private upf file on the server, this user loads a "site" cfg file where all the standards are located. In this standard (cfg) is the MS_DGNLIBLIST defined, and this can't be changed.
I need this overwrite special for this project only, so the overwrite must be defined in the pcf file.
Rik
