Element Information use causes crash
Posted on behalf of user:
Getting the following error in MicroStation V8i Select Series 3 Update 2 (08.11.09.459) on Windows 7 64-bit:
"Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue. Object reference not set to an instance of an object."
This error occurs when attempting to analyze element with the element information tool.
