Hey,
I seem to be having trouble printing some drawings. all of my ref's to do with the actualy project dont print out. But the title block does...... Has anyone run into a problem like this before.
I was playing around with some new MDL's earlier so it might of been that but i have unloaded them all and still nothing.
Anything would be great. Thanks
Don't suppose you work for Hatch in Perth do you?
Make sure you don't have any settings in an attached pen table that may be causing a problem. What sort of plot files are you using, they may be actaully calling up a pen table.
HTH.
The usual culprits I see are
1) elements drawn as construction elements and construction elements "turned off" for plotting by the pen table.
2) levels set to "do not plot".
3) pen table output criteria affecting what gets plotted.
I usually don't see entire files missing though. Could you package up a sample set - DGNs, pen table? Maybe just 1 sheet and 1 ref that is not plotting.
Hey Bear,
What a surprise to see you in here. Yes i do work for Hatch in Perth....Any guess hahaha.
Thatnks for the help.
Simon
